Configures an OSFP area as a normal area.
| area-identifier | Specifies an OSPF area. |
Normal.
Virtual links can be configured through normal areas. External routes can be distributed into normal areas.
The following command configures an OSPF area as a normal area:
configure ospf area 10.1.0.0 normal
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
